/DT/FVMBAG/Iflag
Engine Keyword Time step for control for Finite Volume Method airbag.
- For Iflag = 0,
1
/DT/FVMBAG/Iflag
- For Iflag = 2
/DT/FVMBAG/Iflag
Lambda L_type
Monvol_ID
Definition
| Iflag | Finite volume merge flag.
| Scale factor on time
step. Default = 0.9 (Real) |
| Minimum time
step. (Real) |
| Lambda | Stability
factor. Default = 0.01 (Real) |
| L_type | Time step computation method.
| Monvol_ID | Monitored volume
identifier. (Integer) |
- The and can be defined to ensure stability and a minimum time step size by triggering additional finite volume merges when the FVMBAG entity penalizes the computation.
- When using
/DT/FVMBAG/2, time step is computed as:Where,
- Gas velocity.
- Polyhedron velocity.
- Speed of sound.
- Characteristic length.
The soothing factor is applied using .
