/GRSH3N/GENE
Block Format Keyword Generate a group of 3 node elements by listing the first and last element IDs in the range.
For each list, enter first node and last node (any number of lists may be input, up to 5 per Line). All nodes between first_ID and last_ID are selected.
| /GRSH3N/GENE/grsh3n_ID/unit_ID | |||||||||
| grsh3n_title | |||||||||
| first_ID1 | last_ID1 | first_ID2 | last_ID2 | first_ID3 | last_ID3 | first_ID4 | last_ID4 | first_IDn | last_IDn |
Definition
| grsh3n_ID | 3 node shell group
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| grsh3n_title | 3 node shell group
| first_ID1, last_ID1,...first_IDn, last_IDn | List of first and last 3
node shell identifiers (Integer) |
