/GRTRIA/GENE
Block Format Keyword Generate a group of triangles (/TRIA) by listing the first and last element IDs in the range.
For each list, enter first and last triangle identifier (any number of lists may be
input, up to 5 per Line). All 2D solid triangles (/TRIA) with
identifiers between first_ID and last_ID are
selected.
| /GRTRIA/GENE/grtria_ID/unit_ID | |||||||||
| grtria_title | |||||||||
| first_ID1 | last_ID1 | first_ID2 | last_ID2 | first_ID3 | last_ID3 | first_ID4 | last_ID4 | first_IDn | last_IDn |
Definition
| grtria_ID | Group
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| grtria_title | Group title (Character, maximum 100 characters) |
| first_ID1, last_ID1,...first_IDn, last_IDn | List of first and last
triangle identifiers (Integer) |
