*HOURGLASS
LS-DYNA Input Interface KeywordDefine solid and hourglass formulation for 8-node solid elements.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *HOURGLASS | |||||||
| HGID | IHG | QH | |||||
Definition
| HGID | Hourglass identifier used in *PART. (Integer) |
| IHG | 8-node solid and hourglass formulation.
(Real) |
| QH | Hourglass coefficient. Default = 0.1 (Real) |
- This keyword maps to /PROP/TYPE14 (SOLID).
- IHG=5 is available only for the isotropic materials.
