Block Format Keyword This option allows different default values
which are suitable for implicit calculations.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| /IMPLICIT |
Changed Values
| Option |
Name |
Description |
New Value |
| /DEF_SHELL |
Iplas |
Shell plane stress plasticity flag |
1 (iterative projection with three Newton iterations) |
| Ishell |
Shell formulation flag |
24 |
| Idril |
Drilling degree of freedom stiffness flag |
1 |
| /DEF_SOLID |
Isolid |
Solid formulation flag |
14 |
| /INTER/TYPE7 |
Irem_i2 |
Deactivate the secondary node flag |
1 |
