/LEAK/MAT
Block Format Keyword Specifies effective leakage area of porous airbag fabric materials LAW19 and LAW58 as function of time, pressure, area and other parameters.
/LEAK/MAT/mat_ID/unit_ID
mat_title
Ileakage AscaleT AscaleP
Define leakage for area in contact
AC' fct_IDAC' FscaleAC'
Insert if Ileakage =1
LC AC
Insert if Ileakage =2, 3 or 4
fct_IDLC fct_IDAC FscaleLC FscaleAC
Insert if Ileakage =5
L R
C1 C2 C3
Insert if Ileakage =6
X0 X1 X2 X3
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
mat_title Material title.
Ileakage Effective leakage area formulation flag.
= 0
No leakage
= 1, 2, 3, 4
2
= 5
Fabric leakage model
= 6
Anagonye and Wang leakage model
(Integer)
AscaleT Abscissa time scale factor on function.
Default = 1 (Real)
AscaleP Abscissa pressure scale factor on function.
Default = 1 (Real)
AC' Area coefficient for area in contact 0 ≤ A C ' ≤ 1 .
Default = 0 (Real)
fct_IDAC' Area coefficient function identifier AC'(t) if AC' is equal to 0.
(Integer)
FscaleAC' Scale factor on function AC'.
Default = 1 (Real)
LC Leakage coefficient.
Default function is 0 (Real)
AC Area coefficient.
Default = 0 (Real)
fct_IDLC Leakage coefficient function identifier LC(t), if Ileakage =2 or 3.
Leakage coefficient function identifier L C ( A r e a / A r e a 0 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamitaiaado eadaqadaqaaiaadgeacaWGYbGaamyzaiaadggacaGGVaGaamyqaiaa dkhacaWGLbGaamyyamaaBaaaleaacaaIWaaabeaaaOGaayjkaiaawM caaaaa@41D5@ , if Ileakage =4
Default function is 0 (Integer)
FscaleLC Scale factor on function LC.
Default = 1 (Real)
fct_IDAC Area coefficient function identifier A C ( P ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqaiaado eadaqadaqaaiaadcfaaiaawIcacaGLPaaaaaa@39E2@ , if Ileakage =2.
Area coefficient function identifier A C ( P − P e x t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqaiaado eadaqadaqaaiaadcfacqGHsislcaWGqbWaaSbaaSqaaiaadwgacaWG 4bGaamiDaaqabaaakiaawIcacaGLPaaaaaa@3EBA@ , if Ileakage =3.
Area coefficient function identifier A C ( P e x t / P ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqaiaado eadaqadaqaaiaadcfadaWgaaWcbaGaamyzaiaadIhacaWG0baabeaa kiaac+cacaWGqbaacaGLOaGaayzkaaaaaa@3E80@ , if Ileakage =4.
FscaleAC Scale factor on function AC.
Default = 1 (Real)
L Characteristic length.
Default = 1 (Real)
[ m ]
R Fiber thickness.
Default = L (Real)
[ m ]
C1 Coefficient C1.
(Real)
C2 Coefficient C2.
Default = 1 (Real)
C3 Coefficient C3.
(Real)
X0, X1, X2, X3 Coefficients of Anagonye-Wang leakage area law.
(Real)
  1. The mat_ID must be the same as /MAT/LAW19 (FABRI) or /MAT/LAW58 (FABR_A). Material porosity is active only when corresponding components are referred as external surfaces in /MONVOL/AIRBAG1, /MONVOL/COMMU1, and /MONVOL/FVMBAG1 airbag cards.
  2. Effective leakage area ( A e f f ) formulation:
    Ileakage =1:
    A e f f = ∑ n L C ⋅ A C ⋅ A r e a n
    Ileakage =2:
    A e f f = ∑ n LC ( t ) ⋅ AC ( P ) ⋅ A r e a n
    Ileakage =3:
    A e f f = ∑ n LC ( t ) ⋅ AC ( P − P e x t ) ⋅ A r e a n
    Ileakage =4:
    A e f f = ∑ n LC ( A r e a n / A r e a 0 ) ⋅ AC ( P e x t / P ) ⋅ A r e a n
    Where,
    A r e a 0
    Initial area of the airbag surface
    Note: By default all coefficients and functions are zero.
    Ileakage =5:
    A e f f = ∑ n A r e a 0 L 2 [ ( C 1 Δ P C 2 − C 3 ) ( L − R ) 2 + C 3 ( L λ 1 − R / λ 2 ) ( L λ 2 − R / λ 1 ) ] ⋅ sin α 12
    Δ P = P / P e x t − 1
    Where, λ 1 and λ 2 are the stretches in warp and weft directions and α 12 is the angle between warp and weft directions.
    Note: For LAW19 α 12 = 90 ∘
    Ileakage =6:
    A e f f = ∑ n A r e a 0 ( X 0 + X 1 r s + X 2 r p + X 3 r s r p )
    with r s = A r e a n / A r e a 0 and r p = P e x t / P
  3. Blockage of airbag fabric, due to contact, can be activated in corresponding /MONVOL card. Effective leakage area is calculated with account of the blockage as:
    A r e a n = A r e a n o n _ i m p a c t e d + A C ′ ⋅ A r e a i m p a c t e d
