/MPC
Block Format Keyword Defines multi-point constraints on nodes.
/MPC/MPC_ID | |||||||||
MPC_title |
Card 1 to N
node_ID1 | Idof1 | skew_ID1 | α1 | ||||||
node_ID2 | Idof2 | skew_ID2 | α2 | ||||||
etc | etc | etc | etc | ||||||
node_IDN | IdofN | skew_IDN | αN |
Definition
MPC_ID | Multi-point constraint
identifier. (Integer, maximum 10 digits) |
MPC_title | Multi-point constraint
title. (Character, maximum 100 characters) |
node_IDi | Node
identifier. (Integer) |
Idofi | Degree-of-freedom
(velocity direction). (Integer) |
skew_IDi | Local skew (for each
DOF). (Integer) |
αi | Scale
coefficient. (Real) |
- This option is not available if it is
applied on:
- a translational DOF of a node with a null mass
- a rotational DOF of a node with a null inertia
- User-defined linear relation between nodal velocities.
- The N formats are necessary to define
a kinematic relation between N velocity components. Each term may be expressed
in its own local skew system (Skew_ID):N∑i=1α⋅Viskidof(node)=0
isk = Skew_ID
idof = 1...6
1...3: translational velocity
4...6: rotational velocity
