Runname_run#.sta File
The state files can be used to impose initial state on shell or solids in subsequent runs through the keyword #include or through the keyword /STATE/STR_FILE to read the stress file.
#include TEST_LOI70_0011.sta
/STATE/STR_FILE
0
TEST_LOI70_0011.staComments
- The STA-file contains node and element. Delete the concerned nodes from the node definition of the 0.rad and concerned elements from the element definition (Example: /BRICK, /SHELL, ...) of the 0.rad; otherwise there will be an error in Starter.
