/RWALL
Block Format Keyword Defines the following types of rigid walls: Infinite Plane, Infinite Cylinder, Sphere and Parallelogram.
/RWALL/type/rwall_ID/unit_ID | |||||||||
rwall_title | |||||||||
node_ID | Slide | grnd_ID1 | grnd_ID2 | ||||||
Dsearch | fric | ϕ | ffac | ifq |
XM | YM | ZM |
Mass | VX0 | VY0 | VZ0 |
XM1 | YM1 | ZM1 |
XM2 | YM2 | ZM2 |
Definition
type | Rigid wall type
keyword. (see table below) |
rwall_ID | Rigid wall
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit identifier. (Integer, maximum 10 digits) |
rwall_title | Rigid wall
title. (Character, maximum 100 characters) |
node_ID | Node identifier (moving
rigid wall). (Integer) |
Slide | Sliding flag.
(Integer) |
grnd_ID1 | Node group defining
secondary nodes to be added to the rigid
wall. (Integer) |
grnd_ID2 | Node group defining
secondary nodes to be deleted from the rigid
wall. (Integer) |
Dsearch | Distance for secondary
search. (Real) |
[m] |
fric | Friction. (Real) |
ϕ | Diameter of the
sphere. (Real) |
[m] |
ffac | Filtering factor. The default value depends on the ifq flag (Real) |
ifq | Filtering flag. 5
Default = 0 (Integer) |
XM | X coordinate of
M. (Real) |
YM | Y coordinate of
M. (Real) |
ZM | Z coordinate of
M. (Real) |
Mass | Mass of the rigid wall.
8 If no mass is entered, the rigid wall will have a constant imposed velocity. (Real) |
[kg] |
VX0 | Initial velocity in X
direction. (Real) |
[ms] |
VY0 | Initial velocity in Y
direction. (Real) |
[ms] |
VZ0 | Initial velocity in Z
direction. (Real) |
[ms] |
XM1 | X coordinate of
M1. (Real) |
YM1 | Y coordinate of
M1. (Real) |
ZM1 | Z coordinate of
M1. (Real) |
XM2 | X coordinate of
M2. (Real) |
YM2 | Y coordinate of
M2. (Real) |
ZM2 | Z coordinate of
M2. (Real) |
Rigid Wall Type
- Type
- Description
- PLANE
- ˉ∞ plane
- CYL
- ˉ∞ Cylinder of diameter ϕ
- SPHER
- Sphere of diameter ϕ
- PARAL
- Parallelogram
Surface Input Type
- Type
- Description
- PLANE
- MM1 defines the normal direction
- CYL
- MM1 defines the axis of the cylinder
- SPHER
- M is the center of the sphere
- PARAL
- MM1 and MM2 define the parallelogram
- The first input defines the rigid wall coordinates of one point M or a node_ID in case of moving rigid wall.
- The next input is the coordinate of a point M1 and possibly a point M2 (in case of a moving wall, M1 and M2 have the same motion as node_ID).
- The secondary nodes to a rigid wall can be defined as a group of nodes and/or as nodes initially at a distance less than the distance (Dsearch) from the rigid wall.
- The friction filtering option is only available for a slide rigid wall with friction (Slide =2).
- Filtering flag
ifg
If ifq ≠ 0, the tangential (friction) forces in each secondary node in contact are filtered using a simple rule:
FTf=αFT(t)+(1−α)FTf(t−dt)Where,- FTf
- Filtered tangential force.
- FT(t)
- Calculated tangential force at time t before filtering.
- FTf(t−dt)
- Filtered tangential force at the previous time step
- t
- Current simulation time
- dt
- Current simulation time step
- α
- Filtering coefficient
The flag ifq defines a method for filtering, α coefficient.
If ifq =1, filtering coefficient is directly input by you: α=ffac
If ifq =2, α corresponds to a 3dB filtering level for user-defined frequency (frequency defined in terms of time step number):α=2πNwith 1freq=T=Ndt , and N=ffac
If ifq =3, α corresponds to a 3dB filtering level for user-defined frequency:
α=2πdt⋅freqWhere,- dt
- Time step
- freq
- ffac
- The sphere (SPHER) and parallelogram
(PARAL) are not infinite. For parallelograms, the normal is defined
using:MM1×MM2
and the diameter of the sphere is defined using ϕ .
- Nodal thickness of rigid wall secondary nodes is not taken into account.
- For moving rigid walls with MASS=0 or blank, the rigid wall will have a constant imposed velocity and not an initial velocity.
