Intersect
Extract curves resulting from the intersection of the sketch plane with selected parts or surfaces.
Create Intersection Curves
On the Sketch ribbon, select the
Intersect tool.
- On the toolbar, select Parts to choose parts to intersect with the sketch plane, or select Surfaces to choose surfaces to intersect with the sketch plane.
Select part(s) or surface(s) that intersect with the sketch plane to create
intersection curves.
The intersection curves appear as a dotted red line or curve, and can interact with your new sketch.
