Project
Project selected geometry onto the sketch plane as construction geometry.
Project to a Sketch Plane
On the Sketch ribbon, select the Project tool.
- Select a face or plane as the sketch plane.
Select points, edges, or faces to project onto the sketch plane.
The selected entities are projected onto the sketch plane as dotted construction lines.
Tip: To convert a construction line to a sketch curve,
right-click the construction line and select Create
Curve.
Note: When a sketch plane is defined on the face of a part (or an
impression on the face of a part), the projection curves are generated
automatically. You can turn off this option in the Preferences under .
