Using the Open Workbook in Design Mode
The Open Workbook in Design Mode view is composed of the following sections.
| Section | Description |
| 1 |
Back Exit the Workbook in Design Mode to go back to the Workbooks page. |
| 2 |
Data Table Selected data table. |
| 3 |
Search Columns Allows you to search for columns in the selected data table. |
| 4 |
Data Table Columns Columns to drag to dashboard visualizations and parts. |
| 5 |
Workbook Data Table Editor Displays Data Table Editor layout where you can further configure the data table. |
| 6 |
Home Allows you to go back to the Welcome page. |
| 7 |
Edit Data Table Opens the Edit Data Table Wizard. Enabled when the data table was added using the |
| 8 |
Add Data Table Opens the Add Data Table Wizard. |
| 9 |
Dashboard Selected dashboard where you can add, edit, and delete visualizations, filters, actions, You can also create, edit, duplicate, rearrange, and delete dashboards. |
| 10 |
Columns Columns dragged to the X variable of the visualization. |
| 11 |
Breakdown, Columns, and Rows Allows you to define hierarchical structures for the visualization |
| 12 |
Visualization Variables and Filters Variables and filters that can be defined for the visualization |
| 13 |
New Dashboard Allows you to add a new dashboard. You can also opt to select a template to use. |
| 14 |
Workbook Theme Select the workbook theme. |
| 15 |
Toolbar Toolbar options in the Workbook in Design Mode |
| 16 |
View Go to Workbook in View Mode |
| 17 |
Show Details Displays information available in the Details variable of a visualization |
| 18 |
Filters Filters added on the dashboard |
| 19 |
Visualization Context Menu See Context Menu for more information. |
In this mode, you can also perform the following operations:
- Add dashboard parameters
- Perform synchronization
- Morph visualizations
- Create actions and global filters for the workbook
- View and clear active filters
- Define the workbook theme
- Interact with the visualizations
