Screen printing with conductive ink is the newest form of FPC (called membrane) being
produced today. In this application, carbon/silver (C/Ag) paste replaces the
traditional copper conductor.Figure 3.
Layer Definition: Define silver paste area and stiffener for top and bottom.
Silver Paste Top Layer: Select silver paste top layer from the
artwork layer list.
Silver Paste Bottom Layer: Select silver paste bottom layer from the
artwork layer list.
Stiffener Top Layer: Select stiffener top layer from the artwork
layer list.
Stiffener Bottom Layer: Select stiffener bottom layer from the
artwork layer list.
Checking
Clearance between Silver Paste and Component Pad: Set the clearance
value between silver paste and component pad edge.
Clearance between Silver Paste and Board Outline: Set the clearance
value between the silver paste and board outline.
Clearance between Silver Paste and Stiffener: Set the clearance
value between the silver paste and stiffener.
