Rotation on Axis
Animate an object as it rotates along a selected axis for a set number of turns.
On the Home ribbon, select the Animation
Mode tool.
The Animation Timeline is diplayed. It shows any objects with animation data, their channels, and key frames. - Select an object or group to animate.
On the Animation ribbon, click the Rotation
on Axis tool.
Add the rotations:
- Optional:
Edit the rotations:
To Do this Move the rotation Drag the origin point in the modeling window. Remove or change the order of rotations In the Control Panel, select the rotation and choose from the following: - To remove the rotation, click Remove.
- To change the order, click Move
Up or Move
Down.Note: The animation goes in order of the rotation list.
