Keyboard Shortcuts
Define shortcuts to common operations.
File
| To do this | Press |
| Open | Ctrl + O |
| New | Ctrl + N |
| Import | Ctrl + I |
| Save | Ctrl + S |
| Save As | F12 |
| Save All | Ctrl + Shift + F12 |
| Save a Copy As... | F9 |
| Save Selected | Shift + F12 |
| Close | Ctrl + W |
| Close All | Ctrl + Shift + W |
| Exit | Ctrl + Q |
Edit
| Redo | Ctrl + Y |
| Undo | Ctrl + Z |
| Copy | Ctrl + C |
| Cut | Ctrl + X |
| Paste | Ctrl + V |
| Delete | Delete |
| Rename | F2 |
| Duplicate | Ctrl + D |
| Switch | Ctrl + T |
Edit Blocks
| Super Block | Ctrl + B |
| Expand Super Block | Ctrl + Alt + X |
| Show Name | Ctrl + L |
| Flip | Ctrl + F |
| Rotate Right | Ctrl + R |
| Rotate Left | Ctrl + Shift + R |
| Auto Mask | Ctrl + M |
| Remove Mask | Ctrl + U |
| Restore Mask | Ctrl + Shift + M |
| Left | Ctrl + Shift + L |
| Right | Ctrl + Shift + R |
| Bottom | Ctrl + Shift + Down |
| Top | Ctrl + Shift + Up |
| Vertical | Ctrl + Shift + V |
| Horizontal | Ctrl + Shift + H |
Simulate
| Run | Ctrl + E |
| Compile | Ctrl + Alt + C |
Tools
| To open | Press |
| OML Editor | Ctrl + H |
| Model dialog | Ctrl + Alt + M |
| Context dialog | Ctrl + Alt + D |
| Setup dialog | Ctrl + Alt + S |
| Debug File Viewer | Ctrl + Shift + D |
View
| To view | Press |
| Maximize Window | Ctrl + Alt + 6 |
| Restore Window | Alt + Shift + X |
| Full Screen | Shift + F11 |
| Split Vertical | Ctrl + Alt + V |
| Split Horizontal | Ctrl + Alt + Z |
| Split Window | Ctrl + Alt + W |
| New Window | Ctrl + Alt + N |
Help
| To open | Press |
| Help | Ctrl + F1 |
Miscellaneous
| Close All (Ignore Messages) | Ctrl + Shift + F4 |
Dock Windows
| To open | Press |
| Project Browser | Ctrl + F2 |
| Property Editor | F3 |
| Python Window | F4 |
| Command History | Ctrl + Alt + H |
| Variable Browser | Ctrl + Alt + R |
| OML Command Window | F8 |
| File Browser | Ctrl + Alt + F |
| Demo Browser | F7 |
Modifying Keyboard Shortcuts
You can modify the default keyboard shortcuts in the Preferences dialog.
- From the menu bar, select .
- In the Preferences dialog that appears, under Category, select Keyboard Shortcuts.
- Select a shortcut that you want to modify and enter a new value.
