Annotate Models
Add descriptive text and graphical information for a model.
In the modeling window of a current model, right-click, then select
Create Annotation.
A text box opens for you to add supporting information to your model.
To change the parameters of the annotation, right-click in the text text
box.
A context menu appears with options to modify the text, font style and color.
Add Graphical Annotation
Annotate a model with graphical elements.
You can use an empty super block to annotate a model with graphical elements to help visualize context and structure a diagram.
- Click to add a super block.
- Right-click the super block, and then select Always in Background.
- Right-click the super block, and then select .
Select an image.
Note: You can also apply a background color to the super block.
