Provide archival information for a model including a description and creator
name.
From the ribbon, select the Model tool.
From the Model dialog that opens, select the Properties
tab.
Enter a description and an author or creator name for your model. For lengthy
descriptions, you can select the text editor, outlined in red in the following
figure, and enter your information:
The remaining fields on the tab are automatically populated as
applicable.
