Recommended Settings and Customizations for SimLab
Define settings for a nanoFluidX and SimLab connection.
For the best experience, it is recommended to define the following preferences in nanoFluidX.
- From the menu bar, click to access the SimLab settings.
- In the Preferences dialog, under , select the Enable units for new database checkbox and accept the default units system.
- Define the Number of cores to be used for meshing/particle generation and enable parallel meshing.
Go to
and select your preferred rotation/selection mapping for mouse
settings.Note: In the Applications section, you can review, edit, and transfer keyboard shortcut settings.
- In the title bar of the Model Browser, right-click and add the Material and Material ID columns.
Output Window
The Output window provides all the necessary information of the model and the process that is being executed by the software. It also provides information about any errors that have occurred.
If you intend to use the DataCheck feature for nanoFluidX, enable the Output Window by clicking from the menu bar.
For more information on using the Data Check feature, refer to Verify the model using Data Check.
