Altair HyperMesh
New Features
- Radioss 2025 Solver Profile
- A new Radioss 2025 solver profile has been added.
- New Sets Support: /SET/GENERAL
- All legacy set types have been removed (/GR…, /SURF/..., and so on).
- Automatic Sets Update
- You can now update automatic sets upon mesh modification. This feature is activated via the Sets preference under .
- Safety Tools
- A new Seatbelt Deformer workflow has been added. See the Safety Tools release notes for more information.
Enhancements
- Safety Tools
- See the Safety Tools release notes for more information.
- Airbag Folding Workflows
- Updated workflows and new simulation technology are available for a drastic global airbag folding process time reduction.
- New Supported Keywords
- The following keywords are now supported: /ALE/GRID/FLOW-TRACKING, /CHECK/RFILE/OFF, /DAMP/VREL, /H3D/BEAM/..., /H3D/ELEM/VECT/ACC, /IMPL/MUMPS/OUTCORE, /SENS/RESET, /SENSOR/NIC_NIJ, and /TH/SENSOR.
- Updated Keywords
- The following keywords have been updated: /ANIM/DT, /DEF/SHELL, /FAIL/JOHNSON, /FAIL/SYAZWAN, /FAIL/TAB2, /H3D/DT, /MAT/LAW90, /PROP/TYPE1, /PROP/TYPE6, /PROP/TYPE9, /PROP/TYPE10, /PROP/TYPE18, /PROP/TYPE34, and /SENSOR/ENERGY.
- Orientation Review Tool
- In the Orientation Tab, the display normals and reverse normals features are now available for hexa solid elements. These features are relevant for checking and correcting the orientation of thick shells or cohesive solid element types.
- 1D Elements Orientation Node Update
- A new "Update Orientation" context menu option has been added on the Node_id3 attribute for 3-node springs and beam elements. This feature activates a tool to define a new direction vector and automatically update Node3 coordinates or create a new node. This feature works for a selection of multiple elements.
- Penetration Check Tool
- The Penetration Check tool logic has been enhanced for /INTER/TYPE19 to match solver behavior.
- Find Attached Tool
- Finding elements attached to solver masses, and vice versa, is now possible.
- Model Checker
- A new "Show in Browser" context menu option has been added on all checks. You can use this option to automatically list failed entities in their respective browser view for further actions.
Deprecated Features
- The following solver profiles have been removed: Radioss 2017, Radioss 2018, Radioss 2019, and Radioss 2020.
Resolved Issues
- Beam Node3 is no longer created on export when not defined in the beam element. The issue was fixed in version 2023.1 for all existing solver profiles except Radioss.
- The .inc file format is now listed as an available format when importing a solver deck.
- A segmentation error has been fixed that previously occurred when deleting a /PRELOAD load and then deleting the cross-section previously referenced in the load.
- Selection of curve and definition of scale factors is corrected in /TABLE/1.
