Altair nanoFluidX 2025.1 Release Notes
New Features
Hybrid Precision
In cases with large differences in scale, small changes in variables may be masked, impacting the behavior of the simulation. Running these cases in double precision has a significant runtime penalty and restricts the simulation to flagship GPUs. Hybrid precision offers a solution by making it possible to account for the most important phenomena at a small overhead compared to the equivalent single precision simulation.
Sparse addressing infrastructure
Addressing infrastructure can now be dynamically adjusted to cover only those regions in computational domain with fluid particle presence. This reduces memory consumption in cases with low ratio of fluid volume to overall computational domain volume, allowing for handling larger domain sizes.
64-bit addressing infrastructure
A larger address space to support sparsely populated computational domains with a high ratio of domain size to particle spacing is now used. In practice, this extends the solver capability to handle water management cases with very large domain sizes or very small particle spacings. Due to inherent nature of these cases requiring double precision arithmetic, larger addressing infrastructure is only available in hybrid and double precision executables.
Inquiry probe for regulating inlet region velocity
Relative volume flowrate reading of a probe can now be used to adjust the inlet region velocity. This facilitates linking inflow and outflow rates at the boundaries of the computational domain and maintaining a predetermined volume of fluid within the simulation.
Enhancements
Supporting ParaView 5.13 series
All output and state files generated by the solver and auxiliaries are adjusted to support ParaView versions 5.9.1 to 5.13.2.
Planetary motion day rotation in carrier arm reference frame
Day rotation frequency of a planet gear in a planetary gear system can now be defined in either inertial or carrier arm reference frame. Non-parallel planet day and year rotation axes are also supported when carrier arm reference frame is used to define planet motion.
Extended position file motion treatment
Alternative treatment methods are included in the position file motion definition to calculate velocity and acceleration at position file resolution and improve simulation response to high frequency position files.
Two new tutorials for water management
Two new tutorials have been added for windscreen – cowl water management and cab roof rainwater runoff.
Deprecated Features
Operation modes
Operation modes are deprecated and will be removed in a future release.
Resolved Issues
  • Angle limit constraint in passive rigid body motion now follows the specified rotation range in certain configurations.
  • Missing synchronized surface extractor output at restart/continue output times resulted in VTK errors in nFX[c] jobs with vtkp OutputFormat. The issue has now been resolved.
