Altair Binary Format
Export evaluated data of each approach in Altair Binary format (*.abf).
This option saves evaluated data in .abf format, which provides flexibility to perform custom post-processing in HyperGraph. It is a study-level operation, meaning that data from each successfully evaluated approach will be saved. Currently, Summary Table, Linear Effects Table, and Pareto Chart data is supported.
  1. Do one of the following:
    • From the Study ribbon, Collaborate tool group, click the Export tool.
    • From the menu bar, click File > Export.
    The Save As dialog opens.
  2. In the Save As dialog, select Altair Binary Format (*.abf) for Save as type.
  3. Navigate to your working directory.
  4. In the File name field, enter a name.
  5. Click Save.
