2025.1
Explore the tools used to setup topology.
View new features for Altair HyperWorks 2025.1.
Define topology preferences.
Detect, review, and manage geometric holes, fillets, flanges, and logos.
Set the appropriate parameters/options to obtain the desired mesh by editing the criteria and parameter files.
Mesh controls are used to automate and streamline the meshing process.
Explore the tools used to create topology.
Explore the tools used to edit topology.
The Use Parasolid option, found in multiple Topology tools, helps you in creating/editing geometries using a parasolid geometry modeling kernel.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
