User Interface
Explore the user interface.
RibbonsBrowsersAdjust the ViewEntity SelectorsModeling WindowStatus BarFind and Search for ToolsPages and WindowsTitle BarResults Data in HyperViewPlot Data in HyperGraphAnimate Models
  1. Title Bar
    The title bar displays the name of the file that is currently opened, along with the active product and user profile.
  2. Menu Bar
    The menu bar contains pull-down menus that provide access to standard functions such as file management operations, system preferences, and help. You can also change the active product from the menu bar.
  3. Pages and Windows
    The main display area of the user interface is called a page. Each page can contain up to 16 windows.
  4. Search
    Quickly find and open the tools, panels, and browsers that are available from the ribbons, as well as create entities and solver cards.
  5. Ribbons
    The ribbon allows you to quickly access tools and standard functions, and is located along the top of the user interface. Click on an icon to open the related tool. Hovering over a group of icons may reveal additional tools.
  6. Browsers
  7. Entity Selectors
    Use entity selectors to specify which type of entity you are able to select.
  8. Modeling Window
    The modeling window is where your model is displayed.
  9. Modeling Window - HyperView
  10. Modeling Window - HyperGraph
  11. View Controls
    View controls enable you to control the view and display of your model in the modeling window.
  12. Animation Controls
    View your model in motion using animation controls.
  13. Status Bar
    The status bar displays information pertaining to the currently loaded model, active tools, current collectors, and snap filter options.
