Plot RBE/MPC
Use the Plot RBE/MPC tool to plot RBE and MPC considering a RBE3/MPC with a given weighting factor where the nodes are written in a certain displacement coordinate system.
From the menu bar, click .
The tool displays the degrees of freedom (DOF) of the RBE/MPC in a relevant node displacement (analysis) system and plots the relevant weight/coefficients.
