2025.1
Export various file types from the selected client to another format.
Learn about the CAD readers supported by the application and the options available for exporting CAD geometry data.
Overview of the supported formats, versions, and file extensions.
Use the CATIA Composites Link option to export composite drape data.
View new features for Altair HyperWorks 2025.1.
The following file types can be read, depending upon the active application.
Create a new file.
Open a file.
Import various file types into the selected client.
When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
Load a different solver interface in the application.
Load command files, scripts, solver template files, preferences, or the Metadata Table.
Save all of the data in your current session.
The Diagnostics Information Gathering utility collects diagnostics files in the case of a crash and saves them to a common folder.
Use the FiberSim option to export composite data.
CAD writers provide options for processing data during export.
When a CAD file is exported from the application, a .msg file is created, or appended to, in the current working directory.
Export solver input files.
Export 3D models.
Export plot data in several different formats so that it can be read by other software applications.
Learn about exporting connector files.
If you insert special comment cards into your input deck, you can provide HyperMesh with additional information about the colors and names of entities. You can also use comments to preserve information that is not supported by a particular solver, for example, assemblies or system references.
Export settings for AMF, AVI, H3D, JPEG, and GIF files.
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
Templates can be imported by means of the File > Import menu.
Record a video or take a snapshot of the screen.
Use the Units tool to convert a finite element model from its initial unit system to a new unit system.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
