2025.1
View new features for Altair HyperWorks 2025.1.
Learn how to access and download required model files.
Tutorial Level: Beginner In this tutorial, you will create and edit curves and plots.
Tutorial Level: Intermediate In this tutorial, you will learn how to create bar charts by entering values, importing a data file, or specifying a mathematical expression.
Tutorial Level: Beginner In this tutorial, you will learn how to create complex plots from a data file and add and edit complex data curves by using mathematical functions.
Tutorial Level: Beginner In this tutorial, you will learn how to create polar plots from a data file and add polar plots by using mathematical functions.
Tutorial Level: Advanced In this tutorial, you will learn how to customize the program using the preference file.
Tutorial Level: Intermediate In this tutorial, you will learn how to create surface plots.
Tutorial Level: Intermediate In this tutorial, you will learn how to work with the Axes panel, edit curve attributes, contour line plots, and use the Edit Legend dialog.
Tutorial Level: Intermediate In this tutorial, you will learn how to query data from the surface plot and create and use datum planes.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
