2025.1
View new features for Altair HyperWorks 2025.1.
Tutorial Level: Intermediate In this tutorial, you will generate .json files for training a PhysicsAI model on custom outputs/KPIs from a .csv file summarizing the KPIs of the entire dataset.
Tutorial Level: Advanced In this tutorial, you will use custom global input variables (such as varying material properties, global boundary conditions, and so on) for training.
Tutorial Level: Advanced In this tutorial, you will use custom nodal input variables (such as varying nodal and elemental forces, boundary loads, and so on) for training.
Tutorial Level: Beginner In this tutorial, you will learn the procedure for using your own knowledge point indicators (KPIs) as responses in PhysicsAI.
Tutorial Level: Beginner In this tutorial, you will use PhysicsAI to train your own model.
Tutorial Level: Intermediate In this tutorial, you will be guided through the process of using transfer learning in PhysicsAI with a provided pre-trained model and datasets by taking two routes: using transfer learning and training a model from scratch.
Tutorial Level: Advanced In this tutorial, you will train a PhysicsAI model without simulation results.
Explore the HyperStudy tutorials to learn more about using PhysicsAI in HyperStudy.
Tutorial Level: Advanced In this tutorial, you will use the Shape Encoding Regressor (SER) architecture to predict KPIs.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
