2025.1
Discover MotionSolve functionality with interactive tutorials.
View new features for MotionSolve 2025.1.
MotionSolve® is an integrated solution to analyze, evaluate, and optimize the performance of multibody systems.
Learn how to access and download required model files.
Tutorial Level: Intermediate In this tutorial you will learn how to use Spline3D to model an input which depends on two independent variables.
Tutorial Level: Advanced In this tutorial, you will learn more about the MotionSolve joint friction model, how to model Joint friction in MotionView/MotionSolve, and how to review the friction results.
Tutorial Level: Advanced In this tutorial, you will learn how to model a PTdCV joint (point-to-deformatble-curve) joint.
Tutorial Level: Advanced In this tutorial, you will learn how to model a PTdSF (point-to-deformable-surface) joint.
Tutorial Level: Advanced In this tutorial you will learn how to model a PTdSF (point-to-deformable-surface) joint with a contact force.
Tutorial Level: Intermediate In this tutorial, you will learn how to perform a linear analysis using MotionView and MotionSolve. You will also learn how to interpret its results and use the same for improving the stability of your systems.
Tutorial Level: Intermediate In this tutorial, you will learn how to implement a single input single output (SISO) controller in MotionView and solve it using MotionSolve.
Tutorial Level: Advanced In this tutorial, you will build a model and apply solver variables and differential equations before running the model.
Tutorial Level: Advanced In this tutorial, you will learn about the use of FMU in MotionView and MotionSolve.
Tutorial Level: Advanced In this tutorial, you will learn how to use MotionView and MotionSolve to design a control system that stabilizes an inverted pendulum.
MotionSolve is a system level, multibody solver that is based on the principles of mechanics.
This manual provides a detailed list and usage information regarding command statements, model statements, functions and the Subroutine Interface available in MotionSolve.
