2025.1
This manual provides a list of LS-DYNA input files available in Radioss.
View new features for Radioss 2025.1.
Current Radioss format uses the 12x extension format.
LS-DYNA Input Interface KeywordThis keyword defines an imposed velocity, acceleration, or displacement applied to a node or node set.
LS-DYNA Input Interface KeywordDefine boundary conditions on nodes to fix translation and rotation.
LS-DYNA Input Interface KeywordDefine solid and hourglass formulation for 8-node solid elements.
LS-DYNA Input Interface KeywordDefine user-defined through the thickness integration rules for the composite shell element.
LS-DYNA Input Interface KeywordThis keyword should always be the first card of the input file. Optionally used with *CONTROL_UNITS card to specify model units.
LS-DYNA Input Interface KeywordDefines a node number and nodal coordinates in the global coordinate system.
LS-DYNA Input Interface KeywordDefines a part, which combines material and property information.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
