2025.1
This manual provides a list of LS-DYNA input files available in Radioss.
View new features for Radioss 2025.1.
Current Radioss format uses the 12x extension format.
LS-DYNA Input Interface KeywordDefine a rectangular box in the global or local coordinate system.
LS-DYNA Input Interface KeywordDefines a nodal based moving coordinate system.
LS-DYNA Input Interface KeywordThis keyword defines a fixed coordinate system.
LS-DYNA Input Interface KeywordThis keyword defines a local vector direction.
LS-DYNA Input Interface KeywordDefines a function using tabulated input with offsets and scales.
LS-DYNA Input Interface KeywordDefines a simple smooth function, mainly used to impose a displacement on metal forming tool.
LS-DYNA Input Interface KeywordDefine an element set to delete at a given time value.
LS-DYNA Input Interface KeywordDefine friction table between components.
LS-DYNA Input Interface KeywordDefine a cluster of connection solid elements for post-processing and failure control of the solid connection element.
LS-DYNA Input Interface KeywordDefines stiffness direction of discrete springs.
LS-DYNA Input Interface KeywordDefines a table.
LS-DYNA Input Interface KeywordThis keyword defines a 2D table.
LS-DYNA Input Interface KeywordDefines a 3D table.
LS-DYNA Input Interface KeywordDefines a node and entities transformation(s) used in *INCLUDE_TRANSFORM.
LS-DYNA Input Interface KeywordDefine a local vector direction with nodes.
LS-DYNA Input Interface KeywordDefine solid and hourglass formulation for 8-node solid elements.
LS-DYNA Input Interface KeywordDefine user-defined through the thickness integration rules for the composite shell element.
LS-DYNA Input Interface KeywordThis keyword should always be the first card of the input file. Optionally used with *CONTROL_UNITS card to specify model units.
LS-DYNA Input Interface KeywordDefines a node number and nodal coordinates in the global coordinate system.
LS-DYNA Input Interface KeywordDefines a part, which combines material and property information.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
