2025.1
This manual provides a list of LS-DYNA input files available in Radioss.
View new features for Radioss 2025.1.
Current Radioss format uses the 12x extension format.
LS-DYNA Input Interface KeywordDefines the output frequency for time history data.
LS-DYNA Input Interface KeywordDefines the output frequency for the writing of restart files.
LS-DYNA Input Interface KeywordDefines the output frequency for animation files.
LS-DYNA Input Interface KeywordDefine the contact force and pressure vector and the output frequency for animation files.
LS-DYNA Input Interface KeywordDefine a cross plane section to output the force and moment defined by part set.
LS-DYNA Input Interface KeywordDefine a cross section to output the force and moment defined by a group of nodes and groups of elements.
LS-DYNA Input Interface KeywordDefine the results written in the animation output files.
LS-DYNA Input Interface KeywordThis keyword defines which entities are output to the time history file.
LS-DYNA Input Interface KeywordDefines a list of nodes for output in time history file.
LS-DYNA Input Interface KeywordDefine solid and hourglass formulation for 8-node solid elements.
LS-DYNA Input Interface KeywordDefine user-defined through the thickness integration rules for the composite shell element.
LS-DYNA Input Interface KeywordThis keyword should always be the first card of the input file. Optionally used with *CONTROL_UNITS card to specify model units.
LS-DYNA Input Interface KeywordDefines a node number and nodal coordinates in the global coordinate system.
LS-DYNA Input Interface KeywordDefines a part, which combines material and property information.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
