/MAT/LAW36 (PLAS_TAB)
Block Format Keyword This law models an isotropic elasto-plastic material using user-defined functions for the work-hardening portion of the stress-strain curve (for example, stress versus plastic strain) for different strain rates.
For Solid and SPH elements, this material may account for the nonlinear dependence between pressure and density when corresponding Equation of State is prescribed.
/MAT/LAW36/mat_ID/unit_ID or /MAT/PLAS_TAB/mat_ID/unit_ID
mat_title
ρ i
E ν ε p m a x ε t ε m
Nfunct Fsmooth Chard Fcut ε f VP
fct_IDp Fscale fct_IDE Einf CE
Nfunct > 0: Read 1 + INT((Nfunct -1)/5) cards
fct_ID1 fct_ID2 fct_ID3 fct_ID4 fct_ID5
Fscale1 Fscale2 Fscale3 Fscale4 Fscale5
ε ˙ 1 ε ˙ 2 ε ˙ 3 ε ˙ 4 ε ˙ 5
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
mat_title Material title.
ρ i Initial density.
(Real)
[ kg m 3 ]
E Young's modulus.
(Real)
[ Pa ]
ν Poisson's ratio.
(Real)
ε p m a x Failure plastic strain. 11
Default = 1020 (Real)
ε t Tensile failure strain at which stress starts to reduce. 2
ε m Maximum tensile failure strain at which the stress in element is set to zero. 2
Default = 2.0 x 1020 (Real)
Nfunct Number of functions ( 1 N f u n c t 100 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaqaaaaaaaaa WdbiaaigdacqGHKjYOcaWGobWdamaaBaaaleaapeGaamOzaiaadwha caWGUbGaam4yaiaadshaa8aabeaak8qacqGHKjYOcaaIXaGaaGimai aaicdaaaa@42D3@ ).
(Integer)
Fsmooth Smooth strain rate option flag.
= 1 (Default)
Strain rate smoothing active with linear interpolation if there is more than one curve.
= 2
Strain rate smoothing with natural logarithm interpolation if there is more than one curve.
(Integer)
Chard Hardening coefficient.
= 0
Hardening is a full isotropic model.
= 1
Hardening uses the kinematic Prager-Ziegler model.
= value between 0 and 1
Hardening is interpolated between the two models.
(Real)
Fcut Cutoff frequency for strain rate filtering. Only available for shell and solid elements, Appendix: Filtering. 16
Default = 10000 Hz (Real)
[Hz]
VP Strain rate choice flag. 17
= 0 (Default)
Strain rate effect on yield stress depends on the total strain rate.
= 1
Strain rate effect on yield depends on the plastic strain rate.
(Integer)
ε f Tensile strain for element deletion. 2
Default = 3.0 x 1020 (Real)
fct_IDp Yield factor versus pressure function. 7
Default = 0 (Integer)
Fscale Scale factor for yield factor in fct_IDp.
Default = 1.0 (Real)
[ Pa ]
fct_IDE Function identifier for the scale factor of Young's modulus, when Young's modulus is function of the plastic strain. 16
Default = 0: in this case the evolution of Young's modulus depends on Einf and CE.
(Integer)
Einf Saturated Young's modulus for infinitive plastic strain.
(Real)
CE Parameter for Young's modulus evolution.
(Real)
fct_ID1 Yield stress function identifier 1 corresponding to strain rate ε ˙ 1 .
(Integer)
fct_ID2 Yield stress function identifier 2 corresponding to strain rate ε ˙ 2 .
(Integer)
fct_ID3 Yield stress function identifier 3 corresponding to strain rate ε ˙ 3 .
(Integer)
fct_ID4 Yield stress function identifier 4 corresponding to strain rate ε ˙ 4 .
(Integer)
fct_ID5 Yield stress function identifier 5 corresponding to strain rate ε ˙ 5 .
(Integer)
Fscale1 Scale factor for ordinate (stress) in fct_ID1.
[ Pa ]
Fscale2 Scale factor for ordinate (stress) in fct_ID2.
[ Pa ]
Fscale3 Scale factor for ordinate (stress) in fct_ID3.
[ Pa ]
Fscale4 Scale factor for ordinate (stress) in fct_ID4.
[ Pa ]
Fscale5 Scale factor for ordinate (stress) in fct_ID5.
[ Pa ]
ε ˙ 1 If VP =0 total strain rate for fct_ID1.
If VP =1 plastic strain rate for fct_ID1.
(Real)
[ 1 s ]
ε ˙ 2 If VP =0 total strain rate for fct_ID2.
If VP =1 plastic strain rate for fct_ID2.
(Real)
[ 1 s ]
ε ˙ 3 If VP =0 total strain rate for fct_ID3.
If VP =1 plastic strain rate for fct_ID3.
(Real)
[ 1 s ]
ε ˙ 4 If VP =0 total strain rate for fct_ID4.
If VP =1 plastic strain rate for fct_ID4.
(Real)
[ 1 s ]
ε ˙ 5 If VP =0 total strain rate for fct_ID5.
If VP =1 plastic strain rate for fct_ID5.
(Real)
[ 1 s ]
Example (Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
                   g                  mm                  ms
#-  2. MATERIALS:
##HWCOLOR materials 1 43
/MAT/PLAS_TAB/1/1
MAT_TABULATED_STEEL_EXAMPLE
#        Init. dens.
              0.0078
#                  E                  Nu           Eps_p_max               Eps_t               Eps_m
            221000.0                 0.3
#  N_funct  F_smooth              C_hard               F_cut               Eps_f                  VP
         5        1
#  fct_IDp              Fscale   Fct_IDE                EInf                  CE
# func_ID1  func_ID2  func_ID3  func_ID4  func_ID5
         1         2         3         4         4
#           Fscale_1            Fscale_2            Fscale_3            Fscale_4            Fscale_5
                 1.0                 1.0                 1.0                 1.0               1.001
#          Eps_dot_1           Eps_dot_2           Eps_dot_3           Eps_dot_4           Eps_dot_5
                 0.0                0.01                 0.1                 1.0              1000.0
##HWCOLOR curves 1 59
/FUNCT/1
#title
TrueYieldStressMPa_vs_TruePlasticStrain - QUASI_STATIC
#                  X                   Y
                 0.0              389.67
   0.003269060686992              400.23
   0.006930111818697               412.0
   0.010444667419264               425.0
    0.01364836646806               435.0
   0.018589301580824             452.254
   0.021874379924321             469.641
   0.025339482510186             483.105
   0.028791504254908             494.684
   0.032231428223083             505.957
   0.035658606063999             515.583
   0.039073857673036             524.886
   0.042476834476844              533.05
   0.045868260757615             541.266
   0.049247691998806             548.545
   0.052615532789687              555.47
   0.055971597355424             561.572
     0.0593166151509              568.02
   0.062650302953907             574.173
   0.065972157272864             578.918
   0.069283274188388             584.179
   0.072583138868944             588.852
   0.075872187258015             593.598
   0.079150038252912             597.579
   0.082417501766217             602.191
   0.085673728163777             605.639
   0.088919522946915             609.378
   0.092154789311739             613.072
   0.095379504511807              616.55
   0.098593691533105             619.695
   0.101797797028468             623.305
    0.10499136344905             626.295
    0.10817487992333             629.521
   0.111348320564453             632.813
   0.114511357347318             635.359
   0.117664394244064             637.851
   0.120807432277488             640.171
   0.123940737206559             642.727
   0.127064395848652              645.58
   0.130178020896066              647.79
   0.133282182305355             650.415
   0.136376459004361             652.452
   0.139461485892449             655.142
   0.142536808253643              657.36
   0.145602624330452             659.399
   0.148658992471595              661.25
   0.151706339300304             663.779
   0.154744128728257             665.639
   0.157772590056329             667.195
     0.1607925194482             670.145
   0.163802712305892             671.639
   0.166804116095314             673.679
   0.169796748990641              676.21
   0.172779797696021             677.208
   0.175754158491204             678.631
   0.178719690345003              680.05
   0.181676645262092               681.9
   0.184624849171709             683.687
   0.187564155022526             684.911
   0.190494821916083             686.069
   0.193600270631344             686.606
   0.196220092476069             687.801
   0.199417970430916             689.022
##HWCOLOR curves 2 59
/FUNCT/2
#title
TrueYieldStressMPa_vs_TruePlasticStrain - 10s-1
#                  X                   Y
                 0.0            409.1535
   0.003269060686992            420.2415
   0.006930111818697               432.6
   0.010444667419264              446.25
    0.01364836646806              456.75
   0.018589301580824            474.8667
   0.021874379924321           493.12305
   0.025339482510186           507.26025
   0.028791504254908            519.4182
   0.032231428223083           531.25485
   0.035658606063999           541.36215
   0.039073857673036            551.1303
   0.042476834476844            559.7025
   0.045868260757615            568.3293
   0.049247691998806           575.97225
   0.052615532789687            583.2435
   0.055971597355424            589.6506
     0.0593166151509             596.421
   0.062650302953907           602.88165
   0.065972157272864            607.8639
   0.069283274188388           613.38795
   0.072583138868944            618.2946
   0.075872187258015            623.2779
   0.079150038252912           627.45795
   0.082417501766217           632.30055
   0.085673728163777           635.92095
   0.088919522946915            639.8469
   0.092154789311739            643.7256
   0.095379504511807            647.3775
   0.098593691533105           650.67975
   0.101797797028468           654.47025
    0.10499136344905           657.60975
    0.10817487992333           660.99705
   0.111348320564453           664.45365
   0.114511357347318           667.12695
   0.117664394244064           669.74355
   0.120807432277488           672.17955
   0.123940737206559           674.86335
   0.127064395848652             677.859
   0.130178020896066            680.1795
   0.133282182305355           682.93575
   0.136376459004361            685.0746
   0.139461485892449            687.8991
   0.142536808253643             690.228
   0.145602624330452           692.36895
   0.148658992471595            694.3125
   0.151706339300304           696.96795
   0.154744128728257           698.92095
   0.157772590056329           700.55475
     0.1607925194482           703.65225
   0.163802712305892           705.22095
   0.166804116095314           707.36295
   0.169796748990641            710.0205
   0.172779797696021            711.0684
   0.175754158491204           712.56255
   0.178719690345003            714.0525
   0.181676645262092             715.995
   0.184624849171709           717.87135
   0.187564155022526           719.15655
   0.190494821916083           720.37245
   0.193600270631344            720.9363
   0.196220092476069           722.19105
   0.199417970430916            723.4731
##HWCOLOR curves 3 59
/FUNCT/3
#title
TrueYieldStressMPa_vs_TruePlasticStrain - 100s-1
#                  X                   Y
                 0.0               428.0
   0.003269060686992               440.0
   0.006930111818697               453.0
   0.010444667419264               467.0
    0.01364836646806               478.0
   0.018589301580824               497.0
   0.021874379924321               516.0
   0.025339482510186               531.0
   0.028791504254908               544.0
   0.032231428223083               556.0
   0.035658606063999               567.0
   0.039073857673036               577.0
   0.042476834476844               586.0
   0.045868260757615               595.0
   0.049247691998806               603.0
   0.052615532789687               611.0
   0.055971597355424               617.0
     0.0593166151509               624.0
   0.062650302953907               631.0
   0.065972157272864               636.0
   0.069283274188388               642.0
   0.072583138868944               647.0
   0.075872187258015               652.0
   0.079150038252912               657.0
   0.082417501766217               662.0
   0.085673728163777               666.0
   0.088919522946915               670.0
   0.092154789311739               674.0
   0.095379504511807               678.0
   0.098593691533105               681.0
   0.101797797028468               685.0
    0.10499136344905               688.0
    0.10817487992333               692.0
   0.111348320564453               696.0
   0.114511357347318               698.0
   0.117664394244064               701.0
   0.120807432277488               704.0
   0.123940737206559               706.0
   0.127064395848652               710.0
   0.130178020896066               712.0
   0.133282182305355               715.0
   0.136376459004361               717.0
   0.139461485892449               720.0
   0.142536808253643               723.0
   0.145602624330452               725.0
   0.148658992471595               727.0
   0.151706339300304               730.0
   0.154744128728257               732.0
   0.157772590056329               733.0
     0.1607925194482               737.0
   0.163802712305892               738.0
   0.166804116095314               741.0
   0.169796748990641               743.0
   0.172779797696021               744.0
   0.175754158491204               746.0
   0.178719690345003               748.0
   0.181676645262092               750.0
   0.184624849171709               752.0
   0.187564155022526               753.0
   0.190494821916083               754.0
   0.193600270631344               755.0
   0.196220092476069               756.0
   0.199417970430916               757.0
##HWCOLOR curves 4 59
/FUNCT/4
#title
TrueYieldStressMPa_vs_TruePlasticStrain - 1000s-1
#                  X                   Y
                 0.0               467.0
   0.003269060686992               480.0
   0.006930111818697               494.0
   0.010444667419264               510.0
    0.01364836646806               522.0
   0.018589301580824               542.0
   0.021874379924321               563.0
   0.025339482510186               579.0
   0.028791504254908               593.0
   0.032231428223083               607.0
   0.035658606063999               618.0
   0.039073857673036               629.0
   0.042476834476844               639.0
   0.045868260757615               649.0
   0.049247691998806               658.0
   0.052615532789687               666.0
   0.055971597355424               673.0
     0.0593166151509               681.0
   0.062650302953907               689.0
   0.065972157272864               694.0
   0.069283274188388               701.0
   0.072583138868944               706.0
   0.075872187258015               712.0
   0.079150038252912               717.0
   0.082417501766217               722.0
   0.085673728163777               726.0
   0.088919522946915               731.0
   0.092154789311739               735.0
   0.095379504511807               739.0
   0.098593691533105               743.0
   0.101797797028468               747.0
    0.10499136344905               751.0
    0.10817487992333               755.0
   0.111348320564453               759.0
   0.114511357347318               762.0
   0.117664394244064               765.0
   0.120807432277488               768.0
   0.123940737206559               771.0
   0.127064395848652               774.0
   0.130178020896066               777.0
   0.133282182305355               780.0
   0.136376459004361               782.0
   0.139461485892449               786.0
   0.142536808253643               788.0
   0.145602624330452               791.0
   0.148658992471595               793.0
   0.151706339300304               796.0
   0.154744128728257               798.0
   0.157772590056329               800.0
     0.1607925194482               804.0
   0.163802712305892               805.0
   0.166804116095314               808.0
   0.169796748990641               811.0
   0.172779797696021               812.0
   0.175754158491204               814.0
   0.178719690345003               816.0
   0.181676645262092               818.0
   0.184624849171709               820.0
   0.187564155022526               821.0
   0.190494821916083               823.0
   0.193600270631344               823.0
   0.196220092476069               825.0
   0.199417970430916               826.0
#ENDDATA
/END
Example (Steel with EoS)
#RADIOSS STARTER
/UNIT/1
unit for mat
                   g                  mm                  ms
#-  2. MATERIALS:
/MAT/PLAS_TAB/1/1
#        Init. dens.
              0.0078
            221000.0                 0.3
         5        1
         1         2         3         4         4
/EOS/GRUNEISEN/1/1
EOS_STEEL_EXAMPLE
#                  C                  S1                  S2                  S3
                 457               1.490                   0                   0
#             GAMMA0               ALPHA                  E0
                2.00                 .50                   0
/FUNCT/1
#title
#                  X                   Y
                 0.0              389.67
/FUNCT/2
#title
#                  X                   Y
                 0.0            409.1535
/FUNCT/3
#title
#                  X                   Y
                 0.0               428.0
/FUNCT/4
#title
#                  X                   Y
                 0.0               467.0
#ENDDATA
/END
  1. The first point of yield stress functions (plastic strain versus stress) should have a plastic strain value ε p of zero. The yield stress functions must be strictly positive. The yield stress should be either constant or increasing (no softening to avoid numerical instabilities).
  2. Element deletion:
    • Once ε p (plastic strain) reaches ε p m a x , in one integration point, the element is deleted.
    • If ε 1 (largest principal strain) reaches ε t , the yield stress is reduced using the following relation:
      σ Y d = σ Y ε m ε 1 ε m ε t
    • If ε 1 reaches ε m ( ε 1 > ε m ), the stress in element is reduced to 0 (but the element is not deleted).
    • Once ε 1 reaches ε f (maximum tensile failure strain), the element is deleted.
    • Once the damaged yield stress value σ Y d , interpolated or extrapolated reaches 0, the element is deleted.
  3. The kinematic hardening model is not available in global formulation (N=0 in shell property keyword) that is, hardening is fully isotropic.
  4. In case of kinematic hardening and strain rate dependency, the yield stress depends on the strain rate.
  5. Strain rate filtering is used to smooth strain rates.
  6. The first function in fct_ID1 is used for strain rate values from 0 to its corresponding strain rate, strain rate 1. However, the last function used in the model does not extend to the maximum strain rate; for higher strain rates, a linear extrapolation will be applied. This could lead to instability and/or unusual deformation. This instability can be overcome by repeating the stress strain curve, corresponding to the last strain rate, again with a much higher strain rate.
  7. fct_IDp is used to distinguish the behavior in tension and compression for certain materials (pressure dependent yield). This is available for both shell and solid elements. The effective yield stress is then obtained by multiplying the nominal yield stress by the yield factor corresponding to the actual pressure.
  8. If ε ˙ ε ˙ n , the yield stress is interpolated between f n and f n 1 .
  9. If ε ˙ ε ˙ 1 , function f 1 is used.
  10. Beyond the last point of the plastic strain versus stress input curves, the yield stress is extrapolated.
    Figure 3.
    mat_law36_yield_stress
    Where,
    ε ˙
    Total strain rate for VP =0
    ε ˙
    Plastic strain rate for VP =1
  11. If the last point of the first (static) function equals 0 in stress, default value of ε p m a x is set to the corresponding value of ε p .
  12. Strain rate values must be given in strictly ascending order.
  13. The evolution of Young's modulus:
    • If fct_IDE > 0, the curve defines a scale factor for Young's modulus evolution with equivalent plastic strain, which means the Young's modulus is scaled by the function f ( ε ¯ p ) :
      E ( t ) = f ( ε ¯ p ) E
      The initial value of the scale factor should be equal to 1 and it decreases.
    • If fct_IDE = 0, the Young's modulus is calculated as:
      E ( t ) = E ( E E inf ) ( 1 exp ( C E ε ¯ p ) )
      Where, E and E inf are respectively the initial and asymptotic value of Young's modulus, and ε ¯ p is the accumulated equivalent plastic strain.
      Note: If fct_IDE = 0 and C E = 0, Young's modulus E remains constant.
  14. When you specify ε p m a x or ε t MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH1oqzda WgaaWcbaGaamiDaaqabaaaaa@3927@ and ε m MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH1oqzda WgaaWcbaGaamiDaaqabaaaaa@3927@ , a damage output variable is available using /ANIM/ELEM/DAMG or /H3D/ELEM/DAMG. This damage variable is computed as:
    D = max ε p ε p max , 1 ε m ε 1 ε m ε t MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaqaaaaaaaaa WdbiaadseacqGH9aqpciGGTbGaaiyyaiaacIhadaqadaqaamaalaaa baGaeqyTdu2aaSbaaSqaaiaadchaaeqaaaGcbaGaeqyTdu2aa0baaS qaaiaadchaaeaaciGGTbGaaiyyaiaacIhaaaaaaOGaaiilaiaaigda cqGHsisldaWcaaqaaiabew7aLnaaBaaaleaacaWGTbaabeaakiabgk HiTiabew7aLnaaBaaaleaacaaIXaaabeaaaOqaaiabew7aLnaaBaaa leaacaWGTbaabeaakiabgkHiTiabew7aLnaaBaaaleaacaWG0baabe aaaaaakiaawIcacaGLPaaaaaa@547F@
  15. When ε p m a x is specified and the /NONLOCAL/MAT option is activated, non-local plastic strain is used to compute the damage variable.
  16. When VP = 0 and Fcut is set to the default value, it is automatically updated according to the unit system used for the computation.
  17. When VP = 1, the strain rate dependency is computed considering the plastic strain rate. This approach is more consistent with physics and is closer to a full visco-plastic approach. In that case, the plastic strain rate is always smoothed with a cut-off frequency of 10000Hz that cannot be changed by users.
  18. By default, the hydrostatic pressure is linearly proportional to the density:
    P = K μ
    Where,
    K = E 3 1 - 2 ν
    is the bulk modulus and
    μ = V 0 V - 1 = ρ ρ 0 - 1 .
    An additional Equation of State (/EOS) card can refer to this material in order to define a nonlinear dependency between hydrostatic pressure and volumetric strain. This behavior is only available for solid and SPH elements.
