/SENSOR/ENERGY
Block Format Keyword Describes the sensors used to activate or deactivate an object according to energy.
/SENSOR/ENERGY/sens_ID/unit_ID
sens_title
Tdelay
part_ID subset_ID Iselect
IEmin IEmax KEmin KEmax Tmin
IEtol IEtime KEtol KEtime
Definition
sens_ID Sensor identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit identifier.
sens_title Sensor title.
Tdelay Time delay.
(Real)
[ s ]
part_ID Part identifier for the part monitored for /SENSOR/ENERGY.
(Integer)
subset_ID Subset identifier for the subset monitored for /SENSOR/ENERGY, used if part_ID is not defined.
If part_ID and subset_ID are not defined and Iselect = 1, internal and kinetic energy are from all meshed parts in the model.
(Integer)
Iselect Subset or global energy selector.
= 1 (Default)
Part and subset are used. Only energies for mesh parts are used.
= 2
Global model energy is used (including energy from rigid walls, rigid bodies, and so on).
(Integer)
IEmin Minimum part or subset internal energy.
Default = -1E+30 (Real)
[ J ]
IEmax Maximum part or subset internal energy.
Default = 1E+30 (Real)
[ J ]
KEmin Minimum part or subset kinetic energy.
[ J ]
KEmax Maximum part or subset kinetic energy.
[ J ]
Tmin Minimum time duration before activation when criteria is reached. 5
(Real)
[ s ]
IEtol Tolerance for constant internal energy definition.
(Real)
IEtime Minimum time duration for activation when constant internal energy is reached.
[ s ]
KEtol Tolerance for constant kinetic energy definition.
(Real)
KEtime Minimum time duration for activation when constant kinetic energy is reached.
[ s ]
  1. Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
  2. Sensors can be used to activate or deactivate these elements with /ACTIV.
  3. Sensors can be used to generate animations or h3d frames at specific conditions with the Engine keywords /ANIM/LSENSOR or /H3D/LSENSOR.
  4. Sensors can be used to terminate a simulation at specific conditions with the Engine keyword /STOP/LSENSOR.
  5. For sensor type ENERGY.
    The sensor is activated when the internal or kinetic energies satisfy the criteria for the defined part or subset.
    • Internal energy < IEmin or Internal energy > IEmax during time > Tmin
    • Kinetic energy < KEmin or Kinetic energy > KEmax during time > Tmin
    • Internal energy is constant during IEtime with tolerance IEtol around the mean value
    • Kinetic energy is constant during KEtime with tolerance KEtol around the mean value
