/SENSOR/WORK
Block Format Keyword Describes the sensors used to activate or deactivate an object according to work.
/SENSOR/WORK/sens_ID/unit_ID | |||||||||
sens_title | |||||||||
Tdelay | |||||||||
node_ID1 | node_ID2 | Wmax | Tmin | ||||||
sect_ID | int_ID | rbody_ID | rwall_ID |
Definition
sens_ID | Sensor
identifier. (Integer, maximum 10 digits) |
unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
sens_title | Sensor
title. (Character, maximum 100 characters) |
Tdelay | Time
delay. (Real) |
node_ID1 | Node identifier
1. (Integer) |
node_ID2 | Node identifier
2. (Integer) |
Wmax | Maximum
work. Default = 0 (Real) |
Tmin | Minimum time duration
before activation when criteria is reached. 3 (Real) |
sect_ID | Section
int_ID | Interface or
sub-interface identification number. (Integer) |
rwall_ID | Rigid wall
rbody_ID | Rigid body
- Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
- Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
- For sensor type
WORK:
Sensor is activated when work satisfies the criteria:
during Tmin
Where,- x
- Distance between node_ID1 and node_ID2
- F(sect_ID)
- Force in the selected section force
- F(rbody_ID)
- Force in the selected rigid body
- F(int_ID)
- Force in the selected contact interface
- F(rwall_ID)
- Force in the selected rigid wall
If sect_ID is 0,
If rbody_ID is 0,
If int_ID is 0,
If rwall_ID is 0,
Work of all forces is calculated in the direction N1-N2, it is always positive.
If node_ID2 is not defined (0), the distance x becomes the displacement of the node_ID1
