Force Averaging
The average force is updated in the custom property at every EDEM Time Step.
To complement the motion interpolation during the EDEM
simulation, forces are averaged over the number of Time Steps that EDEM is run. Custom properties for the time-averaged force and
torques acting on a Geometry are created when the Geometry is registered for control
using the getGeometryID method. The averaged values for the last
simulation-step can be retrieved from EDEM when it is not
simulating a Time Step. All averaged values are reset to zero at the start of the next
EDEM simulation-step.
