EDEM Calibration Kits
The EDEM Calibration kits are a collection of EDEM models of standard bulk solids characterization tests commonly used for EDEM material model calibration.
Python scripts for automatically computing and reporting the standard test results are
also included in each kit. The kits are located in the EDEM
installation folder under examples. The workflow consists of copying
the simulation decks, modifying the material model properties in EDEM, running the decks and triggering the Python script for post
processing. Multiple decks can be post-processed at once if they are located in the same
folder tree. For more information about using the calibration kits, see the usage
documentation for each kit.
