GPU CUDA Class Declarations
You can use multiple different particle types with the CUDA API. The CUDA API operates with a generalized set of classes and functions.
To retrieve the radius of an element in CUDA for a Multi-Sphere or a
Sphero-Cylinder, use the following operation:
element1.getPhysicalRadius() ;The
closest equivalent operation which would work for polyhedral particles
is:element1.getVolumeSphereRadius();This is not a syntactical difference, but rather a real difference in the value. In this case it is due to the fact that Polyhedral particles do not have an inherent radius like Multi-Spheres and Sphero-Cylinders.
When
developing API scripts on CUDA, use the following resources to understand
the available functionality:
- Internal EDEM API documentation -
Details the EDEM-specific CUDA functions
and classes and can be found at the following
<EDEM install directory>\202X.X\EDEM\src\Api\Help.- Select any
htmlfile.
- Select any
- CUDA Documentation - Details standard CUDA functionality.
For the complete documentation, see https://docs.nvidia.com/cuda/index.html
- Example code is available on the Altair community page: https://community.altair.com/community.
For more information about implementation of different functions, see GPU CUDA Getter and Setter Functions.
