Set up a Python Virtual Environment
A Python Virtual Environment is a folder containing a standalone Python installation. It is recommended to create a new Virtual Environment for each Python project, as this helps track project dependencies and enables sharing of Python projects.
Create a new Virtual Environment using the following commands (replacing
path\to\myenvwith the desired path for the new folder).Windows
Linuxcd C:\Program Files\Altair\EDEM version\common\python\python3.8\win64 python.exe -m venv --system-site-packages C:\path\to\myenvcd ~/<version number>/altair/common/python/python3.8/linux64/bin ./python -m venv --system-site-packages ~/path/to/myenvOnce the environment has been created, you must activate it so that any further Python commands or scripts will run inside this new version of Python.
Activate the Virtual Environment using the following commands:
Windows (Command Prompt)
Windows (PowerShell)path\to\myenv\Scripts\Activate.bat
Linuxpath\to\myenv\Scripts\Activate.ps1
For more information, see the official Python documentation.source path\to\myenv\bin\activate -
Once the environment is active, see Install EDEMpy to install EDEMpy.
- To deactivate the environment at any time, use the
deactivatecommand.
