Rearranging Cables in a Cable Harness
Randomly place all tubes in a cable harness using the Rearrange cross sections
tool.
- In the model tree, select the cable harness for which you want to rearrange the cable instances.
On the Cables tab, in the
Tools group, click the
Rearrange Cross Section icon.
In the model tree, double-click the cable harness to view the rearranged cross-section.Note: To rearrange the cables inside the cable bundle, from the Modify bundle dialog, click Rearrange.Figure 1. The cross-section of the cable harness before the rearrange.
Figure 2. The cross-section of the cable harness after the rearrange.
