Constraints
Introduction
In the data tree of Flux the node Solver > Optimization > Constraints allows
the user to define some constraints which are structural or physical limitations
imposed by the optimizer, a constraint allow the user to control the shape of the
design with some symmetries constraints, volume values constraints or physical
limits. The short list of the constraints is given below:
| Constraints | Required information |
| Physical constraint |
| Constraints on 2D faces volume |
| Symmetry constraint (defined by direction) |
| Symmetry constraint (defined by angle) |
| Double symmetry constraint (defined by direction) |
| Double symmetry constraint (defined by angle) |
