Replace a Forming Operation
Remove and replace a forming operation in your analysis.
  1. On the Tryout ribbon, hover over a forming operation that you've added to your analysis.
  2. Click the Change Operation tool.
  3. From the Replace Operation window that appears, select the forming operation you want to include in your analysis.
    The original operation is replaced with the new selection.
