Probe Results
Use the Probe Points tool to define a point or set of points at specific co-ordinates and probe/query results. This is useful for verifying experimental results with simulation result.
From the Post ribbon, click the Probe Points tool.
The Probe locations dialog opens. -
Define probe points in the following ways:
- Click directly in the modeling window to create points and populate coordinates.
- Click
in the dialog to add a new probe point then
manually define the coordinates. - Click
in the dialog, select a probe point, then use
the manipulators to adjust its position.
Tip: Click
to import or export a probe point coordinates file. -
Click Calculate on the guide bar
to extract values.
A new Point Probe entity is added to the Post Browser.
A table with extracted values for all variables is populated. This data can be saved to a text file.
On the guide bar, click
to
confirm your selection and remain in the tool or click
to confirm your selection and exit the tool.
