Model Configuration
Three configurations are supported:
- • EN – Strain Life
A model configuration is defined as
follows:
<ModelConfig type="EN" unit="MPa">
</ModelConfig>
| Attribute | Valid Values | Comment |
| type | EN, | Mandatory |
| unit | MPa, ksi, psi | Mandatory |
EN - Strain Life
| Element Tag | Valid Values | |
| <method> | Uni Axial | Muli Axial |
| <stresscombination> |
"Abs Max Principal" "Max Principal" "Signed von" "Critical Plane" "Signed Max Shear" |
NA |
| <survivalfactor> | 0 < Value < 1.0 | 0 < Value < 1.0 |
| <noOfPlanes> | NA | 7 < Value < 93 |
| <correction> |
"GOODMAN" "GERBER" "GERBER2" "SODERBERG" "FKM" "NONE" |
NA |
| <sheardamage> | NA |
"FINDLEY" "NONE" |
| <correction> |
"SWT" "MORROW" "MORROW2" "NONE" |
NA |
| <tensiondamage> | NA |
"SWT" "MORROW" "NONE" |
"FS" "BM" "NONE" |
| <plasticcorrection> |
"NEUBER" "NONE" |
NA |
| <layer> |
"Top" "Bottom" "Worst" |
| <typeofloading> | "Time Series" | "Time Series" |
| <resultinput> |
"STRESS" "STRAIN" |
NA |
