Material Setup
The material setup section is defined
within:
<MaterialSetup type="EN">
</MaterialSetup>
| Attribute | Value Values | Command |
| type | "EN" | Mandatory |
The <MaterialSetup> tag is defined by:
| Element Tag | Valid Values | Comment |
| <UserMaterialFile> | Valid Material file path | Optional |
| <EntityList> | NA | Mandatory Compound Element |
User-Defined Material File
The user-defined materials are optional.
The user-defined materials can be added by providing a valid
.csv filepath.
<UserMaterialFile>C:/Documents/Materials.csv</UserMaterialFile> Entity List
The entity list is defined
as:
<EntityList evaltype="Parts">
</EntityList>
The entity list section has the following attributes:
| Attribute | Valid Values | Comment |
| evaltype | "Parts" | Mandatory |
For Selecting Parts
</EntityList>
- Entity
The entity element tag is defined as:
<entity id="1" matname="Mat_SN(1)" name="part_1” poolname="Global" FL="0" Findley="0.3" Kf="1" Offset="0" SE="0.3" Scale="1" TF="0"> …. …. …. </entity>A valid name must be keyed in to the matname. The material name can be specified from the user-defined materials (.csv/.xml) file or from the HyperLife Material database.
Note: HyperLife evaluation will error out with a warning to log file when a user-defined material is not found in the assigned User Defined material file (.xml).Table 3. name Valid Part name in model file Either name or id is Mandatory. If both are given, id will be used id Valid Part id in model file poolname Valid poolname for the entity type Optional
Note: If no poolname is given, default poolname of the entity will be assumed.Scale Valid value NA Table 4. SN Material Attributes (Valid Only for SN Analysis) Attribute Valid Values FL 0 < Value SE 0 =< Value Findley 0 =< Value TF 0 =< Value Kf 1.0 =< Value Table 5. EN Material Attributes (Valid Only for EN Analysis) Attribute Valid Values SEe 0 =< Value SEp 0 =< Value Kf 1.0 =< Value - Surface Finish
The Surface Finish element tag is defined as:
<SurfaceFinish Option="NONE">0.1</SurfaceFinish>Element Tag Valid Values <SurfaceFinish> Option "NONE
"POLISH"
"GROUND"
"MACHINE"
"HOTROLL"
"FORGE"
"USER"
Value 0 < Value <1.0 - Surface Treatment
The Surface Treatment element tag is defined as:
<SurfaceTreatment Option="NONE">0.1</SurfaceTreatment>Element Tag Valid Values <SurfaceTreatment> Option "NONE"
"NITRIDED"
"SHOTPEEN"
"COLDROLL"
"USER"
Value 0 < Value < 2.0 - Temperature Factor
The Temperature Factor element tag is defined as:
There are three options available for temperature factor:<TemperatureFactor Option="NONE"></TemperatureFactor>- NONE
- User Defined
- FKM
Temperature factor: NONE<TemperatureFactor Option="NONE"></TemperatureFactor>Element Tag Valid Values <TemperatureFactor> Option "NONE" Value 0.1 (Default) Temperature factor: USER DEFINED<TemperatureFactor Option="USER DEFINED" Value="1"></TemperatureFactor>Element Tag Valid Values <TemperatureFactor> Option "USER DEFINED" Value 0 < Value < 1.0 Temperature factor: FKM<TemperatureFactor Option="FKM"> <Temperature Option="ISOTHERMAL">150</Temperature> <Type>FINEGRAIN STRUCTURAL STEEL</Type> </TemperatureFactor>Element Tag Valid Values Valid Temperature Values <TemperatureFactor> Option "FKM" NA <Temperature> Option "ISOTHERMAL" NA <Type> "OTHER STEELS"
"GJL"
"GJS"
"GJ"
"GJM"
150 (default)
100 < Value < 500
"FINEGRAIN STRUCTURAL STEEL" 150 (default)
60 < Value < 500
"ALUMINIUM MATERIALS" 150 (default)
50 < Value < 200
