Delete an Explosion
Click the Explode tool.
In the Exploded View panel, select an explosion from the Explosions list.
Tip: Multiple explosions can be selected to be deleted.
Delete the explosion(s) using one of the following methods.
- Click Delete (located at the bottom of the panel).
- Press the Delete key on the keyboard.
The selected explosion is removed from the list.
