show assembly
Shows assemblies in the active model.
show assembly all
show assembly displayed
show assembly <label>
show assembly <labellist>
show assembly marked
show assembly <range>
show assembly select
Arguments
- all
- Show all components.
- displayed
- Show displayed assemblies.
- <label> <labellist>
- Show assemblies based on labels or lists (wildcards supported). For
example,
"Rigid Barrier", Bump??, back*andhinge, handle. - marked
- Show marked assemblies.
- <range>
- Show assemblies based on IDs. For example,
1-3,8,13-20,25?,3*. - select
- Shows/hides entities interactively selected from the modeling window.
Examples
Show all assemblies:
show assembly allShow assemblies by label:
show assembly "hinge, handle"
