show measure
Shows measures in the active model.
show measure all
show measure displayed
show measure <label>
show measure <labellist>
show measure marked
show measure <range>
show measure select
Arguments
- all
- Shows all measures.
- displayed
- Shows displayed measures.
- <label> <labellist>
- Shows measures based on labels or lists (wildcards supported). For
example,
"Measure *", Measure2, MyMeasure*and"Measure 1",Measure2, MyMeasure*. - marked
- Shows marked measures.
- <range>
- Shows measures based on IDs. For example,
1-4,9,13?,3*. - select
- Shows/hides entities interactively selected from the modeling window.
Examples
Show measures by
range:
show measure 1-2Show measure by
label:
show measure "Static MinMax Result"
