xy axisvertical
Copy, create, cut, delete, edit, and paste an axis, either defined by a range or the marked entity.
xy axisvertical copy <mark|marked|range>
xy axisvertical create <mark|marked|range>
xy axisvertical cut <mark|marked|range>
xy axisvertical delete <mark|marked|range>
xy axisvertical edit <mark|marked|range>
xy axisvertical paste <mark|marked|range>
Arguments
- copy
- Copies the selected entity.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- Define the range for the entity you want to apply the action to.
- create
- Create a datum.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- cut
- Removes the selected entity from the Plot Browser and
deletes it from the current session.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- delete
- Deleted the selected entity.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- edit
- Edit the selected entity's properties.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- paste
- Pastes the selected entity into a window.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- Define the window range for the entity you want to apply the action to.
Examples
Edit the axis
properties:
xy axisvertical edit range="p:all w:all i:all" format=Scientificxy axisvertical edit range="p:all w:all i:all" color=2
