xy note
Copy, create, cut, delete, edit, and paste notes, either defined by a range or the marked entity.
xy note copy <mark|marked|range>
xy note create <mark|marked|range>
xy note cut <mark|marked|range>
xy note delete <mark|marked|range>
xy note edit <mark|marked|range>
xy note paste <mark|marked|range>
Arguments
- copy
- Copies the selected entity.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- Define the range for the entity you want to apply the action to.
- create
- Create a datum.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- cut
- Removes the selected entity from the Plot Browser and
deletes it from the current session.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- delete
- Deleted the selected entity.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- edit
- Edit the selected entity's properties.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- paste
- Pastes the selected entity into a window.
- mark
- mark=<marklabel>
- marked
- <true/false>.
- range
- Define the window range for the entity you want to apply the action to.
Examples
Edit note
properties:
xy note edit range="p:all w:all i:all" bordercolor=2xy note edit range="p:all w:all i:all" attachto=window
