::SetEntryText
This command sets the displayed value of an mdl3StateEntry widget. The raw value of the widget is not affected. The evaluated value of the entry can be affected depending on the force argument.
::model::mdl3StateEntry::SetEntryText path text force
MotionView Tcl GUI
This command sets the displayed value of an mdl3StateEntry widget. The raw value of the widget is not affected. The evaluated value of the entry can be affected depending on the force argument. See below.
- path
- The full path to the mdl3StateEntry of interest. The path argument is the return value of the model::mdl3StateEntry procedure used to create an mdl3StateEntry.
- text
- The text that will be displayed in the widget.
- force
- Bool value. Defaults to true. Determine if the evaluated value is over-ridden.
To set the entry text of an mdl3StateEntry
widget:
model::GetClientHandle clnt
clnt GetModelHandle mdl
clnt ReleaseHandle
mdl InterpretEntity entPnt Point p_0 "\"Point 0\""
mdl ReleaseHandle
set dlg [toplevel .dlg]
set frm [frame $dlg.frm -padx 10 -pady 10]
grid $frm -row 0 -column 0 -sticky nesw
set lbl [ label $dlg.frm.lbl -text "X" -width 3 -anchor w ]
grid $lbl -row 0 -column 0 -sticky nws
set stEntry [model::mdl3StateEntry .dlg.frm.stEntry entPnt "x" ]
grid $stEntry -row 0 -column 1
model::mdl3StateEntry::SetEntryText $stEntry "Forced Text" 1
entPnt ReleaseHandleErrors
None.
